Can the wiring track on rear of dash clocks be replaced
Guys
Ive just tried to replace the bulbs on the dash clocks and have found the ones on the outer edge no longer work and the copper trackwork on the plastic sheet has worn off so the bulbs can no longer make connection to work!
Wondering if that sheet that has the wiring tracks on it can be swapped out to fix this??
If so , would be interested if someone had a spare set of dials tht are maybe no good to them so i can sort this?
Cheers Rich
Cheers Rich
Re: Can the wiring track on rear of dash clocks be replaced
If you have a soldering iron,solder and a small bit of wire
you can solder onto the back of the bulb and onto the track.
I have a 96 le turbo , any chance you might know the type i have fitted??
