eml ON
eml ON
Yesterday while driving the l,e the engine management came on, the car drives starts and runs fine
When I got home I paperclip tested it and this is how it reads
96 hot start valve high voltage
117 waste gate valve low voltage
144 no imobiliser signal recived
145 incorrect imobiliser signal
I have not had no issues up to this point and like I said everything drives just fine
Any ideas what can cause this
Re: eml ON
Might be a dodgy earth....i had my airbag light come on once...the earth strap to the block was loose.
Re: eml ON
Final got round to looking at the issues I have had lately
I removed the battery for 24+ hours to reset the ecu and lost the imobiliser issuse
Today I removed the amel plug the wires looked ok on the plug till I lifted it and one of the wires came straight out
So solder this back on and rebuilt it so fingers crossed that's solved that problem
Looked at the hot start valve and cannot see no obvious isusses so did the good old faithful unplugged it and plugged it back in I'll give it a try later and see what happens
Re: eml ON
And fixed
I highly recommend the unplugged and plug back in method lol
