Outside temperature sensor
I've just received my new outside temperature sensor as the display was just showing --.-
Stupidly, I reached around underneath the near side of bumper, found what I thought was where you plug the sensor in to and went and bought the sensor. Received today, gone to connect it up, but doesn't fit the connector, so I've had a further look around that area and found another cable, however whatever was on the end of it has been cut off by a previous owner, is there a way to repair this, ie put a spade connector on the end of each wire and connect to the sensor?
Re: Outside temperature sensor
It should just be 2 wires just cut the plug off the new sensor and just block connect them or solder a new plug and short lenghr of wire on from an old harness if you want it doing correct
Users browsing this forum: No registered users and 67 guests
