Main beam not working
Can someone help me. No main beam and looking for a wiring diagram and the location of the main beam relay. I know it's behind the fuse box but what one as there are about 8 there. Stumped.
Re: Main beam not working
Hi there - I think you’ll find it has a white base, designated K73 in the wiring diagram - sorry I haven’t got my Haynes with me at the mo. Lights are powered by fuses F3 and F23 which are both 10A.
Thanks cliff I will have a look for that relay. Not the best of access though. If you find a diagram that would be great.
Hi, if you send me a private message on the forum with your email address I can send you a snapshot through....
Email address sent Cliff. Many thanks for your help.
Hi Andrew. Looked at wiring diagram on laptop but not clear enough to make out even tried print out. Might have to get a Haynes manual also. No feed to either fuses so trying to find white relay and will let you know how I get on. Regards Frank.
I can email you another copy on Monday - that was an extract from a pdf version - I have the “real book” but didn’t have it to hand. If I don’t send, remind me.
Just scanned and sent, you have early and late model diagrams in case and I checked they’re readable. Good luck!
Users browsing this forum: No registered users and 68 guests
