Fault code 15 - Oxygen sensor
by SukySaggi » Fri Oct 08, 2004 6:26 pm
Got the above error code :cry: , is it possible to just unscrew the sensor and clean it with something or do I need to buy a new sensor.
SukySaggi
by SukySaggi » Mon Oct 11, 2004 12:43 pm
Poo! :x
Got fault 13 as well now. Coolant Temperature Sensor voltage high.
Help anyone?
SukySaggi
by Kieran_Burns » Mon Oct 11, 2004 6:50 pm
You may as well replace the Lambda sensor - the difference in the car is quite noticeable - they're about £70
Kieran_Burns
by SukySaggi » Wed Oct 13, 2004 3:11 pm
Fault 13 has cured itself!
The oxygen sensors a bit tight to unscrew, any help with this?
SukySaggi
by SukySaggi » Fri Oct 15, 2004 2:35 pm
Got fault 13 which was oxygen sensor. [img]/sad.gif[/img] Got that changed and fault cleared. [img]/smile.gif[/img]
Got fault 15 now which is CTS sensor Voltage High. [img]/sad.gif[/img] This error came up before about 18 months ago and cost me over £150 to fix. :cry: :x (this was at Vauxhall before I even heard of ClubCalibra.) I had the sensor changed then and still had the fault. :x The techy checked the wiring and told me there was a break in the wire. He fixed that and everything was fine. [img]/smile.gif[/img]
Now that the fault has come up again :shock: I want to check the wires but don't even know what the coolant temp sensor looks like or where it is. :cry:
Please help.
SukySaggi
by Rusty_CallyT » Fri Oct 15, 2004 4:04 pm
bolted into the rad with a plug on it
Rusty_CallyT
by SukySaggi » Mon Oct 18, 2004 10:54 am
There's 2. One on the top, one on the bottom. What's what?
SukySaggi
