Changing indicator arm
by VivSE5 » Sun Oct 10, 2004 1:54 pm
How do I do it? (well my other half)
Not sure because of the air bag.
Hes got the surround off ok, but theres two screws behind steering wheel
to release the cowling because of the airbag.
Doesnt want it all to go BANG :shock:
Garage job?
Thanks in advance
VivSE5
by Mark1 » Sun Oct 10, 2004 2:19 pm
Just looked in Haynes book and it doesn't say anything about the airbag.
Disconnect the battery neg lead
turn the streeing wheels as necessary to expose the 2 front streeing column shroud screws
remove the 3 securing screws from the underside if the lower column shroud, then remove both the upper and lower shrouds
disconnect the wiring from the switch
depress the switch retaining clip and remove the switch from the housing.
