Bulb failure warning light.
by Jas » Mon Nov 22, 2004 12:21 pm
Hi All
When drving with lights on a warning light on dash is illuminated.
Checked in the hand book and it's the bulb failure warning light (the one without the brackets). But when I check my headlights, sidelights and taillights they are all working. So why have I got the warning light?
Any thoughts!!
Jas
by BazV6er » Mon Nov 22, 2004 1:22 pm
hi jas,
sometimes my lights come on now and again on my new lexus lights and my front light i always check that theres no corrosion on the terminals and check the earth on the body.Is it the big bulb warning light or the small one.
by FatLadZ » Mon Nov 22, 2004 1:22 pm
check that your brake switch is operating correctly on the brake pedal
fatz
FatLadZ
by Jas » Mon Nov 22, 2004 1:49 pm
BRake pedal switch is working fine and I checked the condition of the contacts for all the bulbs even though they were all working.
Cal2616v : Yes it's the big bulb warning light.
Jas
by BazV6er » Mon Nov 22, 2004 4:32 pm
well check your rear lights when it comes on ?or it could be the front ones
by SukySaggi » Mon Nov 22, 2004 4:40 pm
The big light is usually for the front lights. Turn your side lights on and then check the bulbs and then turn your headlights on and check the bulbs.
Also check the high beam and spot lights.
SukySaggi
by benjamin298 » Mon Nov 22, 2004 10:08 pm
Hi i had a similar problem with my rear lights everthing seemed fine.In the end it was the bulbs i got someone to sit on the brake peddle and form inside the boot tapped the back of the brake bulb and this kept cutting out the only way i found of stopping this was to replace both bulbs and this cured my problem.Hope this helps:?:
benjamin298
by Jas » Tue Nov 23, 2004 10:31 am
Cheers all I'll try out your suggestions.
Jas
by carl_freeman » Tue Nov 23, 2004 10:38 pm
also, not sure if the license plate illumination lights can trigger it if they fail?
check them...
carl_freeman
RE: The Wedding
by Davidch » Fri Dec 03, 2004 2:01 pm
Did you find the problem?
Davidch
RE: Bah Humbug
by Jas » Fri Dec 03, 2004 3:29 pm
No nothing has worked up to date!!!
Jas
by Fostersice17 » Mon Dec 06, 2004 5:29 pm
It does it on mine,I have afterburners and one of the warning lights always stays on (due to the led bulbs) But i have normal bulbs in the brakes and that warning light sometimes comes on even when they are working.Im gonna take the warning bulbs out soon.
Fostersice17
by gazcallyt » Fri Dec 10, 2004 2:58 pm
Last time I had a similiar problem to this, was because the filament in the brake/sidelight had melted to each other, lights worked fine, but it brought the warning lamp on, one new bulb later, problem solved.
Gaz.
LET the fun begin.
Users browsing this forum: Google [Bot] and 28 guests
