fuel computer, fuel sensor calibration.
by dmiddle2 » Fri Dec 24, 2004 3:18 pm
I wonder if I could ask if anyone knows anything about how to do this:
I have installed a fuel comp to my SE7. All readings worked fine, except for being wildly inaccurate. I sent it to Ian to calibrate it for a 2.0 ecotec and now the readings it gives are accurate, but the range just shows as 'L'.
I know that this means I have to recalibrate the tank sensor, as per Ians instructions here <a href="http://www.ian.till.btinternet.co.uk/abs-zero/FC/TankCals.htm" target="_blank">http://www.ian.till.btinternet.co.uk/abs-z...FC/TankCals.htm</a>.
I am having difficulty finding it, however and wondered if anyone knows the location of the fuel tank sensor on the later ecotecs? I have found where the picture was taken in the example, but mine simply doesn't look like that!
Any help would be greatly appreciated.
Thanks
Dan
dmiddle2
by sofaman » Sat Dec 25, 2004 2:19 pm
Not really much help but, the fuel tanks sensor unit is built in with the fuel pump inside the the tank. If u can find the fuel pump then there is 2 small connetors comin from it. Hope this helps a little.
BTW how much did u pay for you fuel computer?? and where from?
Cheers sofa
sofaman
by dmiddle2 » Tue Dec 28, 2004 2:35 pm
That might be of help as the workshop manual covers the removal of the fuel pump.
The fuel comp cost about £30 incl p&p off e-bay. Bargain (+£15 for reprogramming it)
Thanks again
Dan
dmiddle2
