Relays
by sofaman » Thu Jan 20, 2005 4:43 am
This maybe a daft question but:-
I'm wiring up some extra interior lights. I've sorted the supply out but i'd like to use a seperate power supply to feed the extra lights.
Am I right in thinking a relay will take a supply from the lights via + and -
then have another + and - connection , + from battery (fused) - out to the extra lights.
Right or wrong, if so why?
is there a type of relay that I need?
Cheers in advance, sofa
sofaman
by SprintV8 » Fri Jan 21, 2005 3:11 am
Relay terminal's.
Marked 30 is Live via a fuse
Marked 85 this goe's to ground/Earth
Marked 86 This is the feed from your switch.
Marked 87 This goes to your Light's/Fan accs.
More details Here
<a href="http://www.vehicle-wiring-products.co.uk/VWPweb2000/relays/relays.html" target="_blank">http://www.vehicle-wiring-products.co.uk/V...ays/relays.html</a>
or here
<a href="http://www.painlesswiring.com/" target="_blank">http://www.painlesswiring.com/</a>
SprintV8
RE: Relays
by sofaman » Fri Jan 21, 2005 3:47 am
you are a star sir
thank you for the info and all your effort :-)
sofaman
