wiring loom fault finding
[img]/sad.gif[/img] does anybody know where i can get a wiring loom tested i live just outside edinburgh
it is for a 16v redtop the loom was cut in half by a moron before i got the car a pal has heat sealed the loom but i have the engine management light on all the time and the car is running like a bag of .......you know what
i just cant find another loom the same as it is a red top but it does not have a distributor
p.s dont worry guys this is not my turbo its another car
MIKECALIBRA1
There isn't one.
You'l have to use schematics in the back of the haynes book and a DMM to measure each signal wire to see if it goes to the right place.
well if the car tuns over, fires up and actuall starts and idels, then there can't be much wrong with it. As the ECU light is on, then you can get a TECH1 or TECH2 reader on it to look at the codes, your do it yourself for free with a paper clip. See my guide
<a href="http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/fault_codes/fault_codes.htm</a>
There were two types of C20XE, M2.5 and M2.8 (the fuel system). As you have a DIS (no dizzy), then you want M2.8 C20XE engine stuff. These are common and you will find these in Astras, Cavaliers and Calibras.
There isn't one.
Alan Knight (Topbuzz)
W: www.topbuzz.co.uk
E: webmaster@topbuzz.co.uk
MIKECALIBRA1
Users browsing this forum: No registered users and 32 guests
