FRONT FOGS ON 8V
by CHRIS173 » Sat Feb 28, 2004 2:26 pm
I would like to know if i can fit fog lights in my 8v(se3) where they are normally fitted on other calibras ie next to dipped beam.Is it possible to do this. :?
CHRIS173
by CHRIS173 » Sat Feb 28, 2004 2:39 pm
I haven`t had the plate off,but i`ll do it over this weekend.T hanks for the quick response. [img]/biggrin.gif[/img]
CHRIS173
by CHRIS173 » Sat Feb 28, 2004 2:55 pm
KENNY,
sorry to be a pain. I took the blanking plate off and hey presto there`s a 3 pin connector behind it,is that correct so far. [img]/laugh.gif[/img] After taking the covers off the back of the haedlights there`s no fitment for the bulb.Does it look like i`ll have to buy some 16v headlights
CHRIS173
by Fraz » Sat Feb 28, 2004 7:51 pm
ther ewill be a plastic blank plug at rear of the light..just take that out, not sure if it has to be cut out or just pops out...then get the conections from a 16v calibra headlight...the wirles also and you should fine the conector in the negine bay ..you will also need he relay from the fuse box ...conect it all up and there you go front foglights
by ecosseM » Tue Mar 02, 2004 2:50 pm
been there and done it with my SE4. once you fitted headlights with fogs in them, its honestly, a 10 min job.
parts needed are;
2x headlights
1x front fog switch
1x front for relay.
whole job from start to finish should take, max, 2 hours.
ecosseM
by Dan Willis » Tue Mar 02, 2004 3:31 pm
<!--QuoteBegin-ecosseM+--><div class='quotetop'>(ecosseM)</div><div class='quotemain'><!--QuoteEBegin-->been there and done it with my SE4. once you fitted headlights with fogs in them, its honestly, a 10 min job.
parts needed are;
2x headlights
1x front fog switch
1x front for relay.
whole job from start to finish should take, max, 2 hours.<!--QuoteEnd--></div><!--QuoteEEnd-->
I love it... a 10 min job that should take, max, 2 hours... like ALL DIY jobs then [img]/wink.gif[/img]
LOL!!!
Dan
by ecosseM » Tue Mar 02, 2004 3:43 pm
erm, go back and read it. ITS A 10 MIN JOB ONCE THE HEADLIGHTS ARE FITTED. :oops:
ecosseM
by CHRIS173 » Fri Mar 05, 2004 7:07 pm
Ok, so when you say "once you have fitted the headlights",does that mean i will need some 16v headlights.If so any idea how much i should pay for a s/hand set,and whereabouts in the engine bay did you find the wires & connections (if you did that is!!),are they taped up somewhere as kenny said.P.S.How much did you pay for the relay & the switch.
Thanks for the reply by the way. [img]/biggrin.gif[/img]
CHRIS173
by ecosseM » Sun Mar 21, 2004 7:56 pm
all the wires are in gm loom. i got switch and relay for nowt from a cav gsi i was breaking. you'l get them no bother from a breakers of many cavaliers, sri's, cd's etc. headlights, hmm, they could cost you £20 plus each, just hunt about.
ecosseM
by ecosseM » Thu Mar 25, 2004 3:30 pm
hi, just thought ad say, thteres a guy advertising the breaking of a 16v calibra mon general forum, its got lights/switch/relay on it inthe pic's shown. ad say be quick though.
ecosseM
knocking sound????
by piltz2004 » Sat May 22, 2004 6:32 pm
Hi Lads (and Ladettes) I've got a similar problem, I've found the connectors behind the switch blanking plate, ive even founf the bulb holder and relevant wires inside the light cluster but here's the catch ONLY IN ONE FECKING SIDE, looks like whoever has owned the car before me has had to get a new light cluster for the offside which has all the connectors wires and bulb holders for the fog light, but the original light cluster on the near side doesn't anyone got a near side light cluster with a fog lamp holder and connector in it??? Oh and while I'm at it, anyone got a front fog switch and relay?
piltz2004
by piltz2004 » Thu Jun 24, 2004 12:14 pm
Just in case anyone was still interested in this topic I have found out that you need specific front light clusters which include the fog lamp wiring and bulb holders inside them the ones (which I have now replaced) on my SE1 had no wiring or bulb holders and the fog lamp lens was silvered off. So to clarify you cant modify a light cluster which doesn't have the fog lamp bits in it.
piltz2004
Users browsing this forum: No registered users and 33 guests
