Trying to install a trip computer...
I've got hold of a trip computer out of another 16v Calibra. Looking at the plug under the bonnet pin D has a brown/red wire going to it (which apparently means I have the loom for it ),but I cant find the yellow plug any where.I've had the glove box and the radio out and the plug doesn't seem to be there.Is there any other way I can see if the loom is actually in the car?
noelboy
Hi, Well mine was hanging behind the head unit mate.
Or sometimes they fall behind glove box, Have a look there .
Mine was tucked between the plastic flap at the side of the radio tray and the glovebox side trim, so you couldn't see it from the glovebox side, pure luck and me being stubborn by following all the wires that I found it..
For reference, the foam covered thing in the middle/bottom right is the wiring for the Oil & volt gauge, just to give you an idea of whereabouts the pic is showing.
Leigh
<!--QuoteBegin-Dawson16v+--><div class='quotetop'>(Dawson16v)</div><div class='quotemain'><!--QuoteEBegin-->Leigh - have you got a pic of the loom under the handbrake for the switch??<!--QuoteEnd--></div><!--QuoteEEnd-->
Only this one...
or this one (FC switch plug is the small white one on the right from memory..)
Only this one...
Leigh
Sefton Park
I paid £50 for mine from V-Tuning. I did not have the under carpet loom to the switch, so I had to install that to the large multiplug in the passenger footwell. I found the yellow plug by removing the oil pressure and volt meter dials and reaching upwards from there. It was cable tied, so I have to cut that and pull it upwards to the trip computer location.
dtm_chris
