Paper Clip
Paper Clip
by jeff » Mon Mar 07, 2005 1:02 pm
Hi does anybody know why the paper clip test does not work on my 1998 ecotec 2 ltr jeff
jeff
by coolshades » Mon Mar 07, 2005 2:58 pm
out of curiocity what is the paper clip test
coolshades
by Dan Willis » Mon Mar 07, 2005 3:01 pm
<a href="http://www.topbuzz.co.uk" target="_blank">www.topbuzz.co.uk</a> - error code reading on the ECU.
No idea if/why it doesn't work on the Ecotec - I thought it did.
Dan
by BenW » Mon Mar 07, 2005 3:34 pm
Works on my Ecotec. I do remember reading that it doesn’t work on some (or that some people had trouble at first)...not sure, long time ago, sorry!
BenW
by Fraz » Mon Mar 07, 2005 4:18 pm
some need the engine running ..others require just the ignition lights on.try both ways
by Stupink » Mon Mar 07, 2005 4:27 pm
if all above fails, your just not making the connection right, have corroded contacts or a dodgy loom.
Whats your actual problem? you don't allways need the codes, so if you cant get them for whatever reason.
by jeff » Thu Mar 10, 2005 10:37 am
Thanks for the help there was a bit of corrosion but made the connection the management light just goes out but not flashing any codes
jeff
Users browsing this forum: No registered users and 47 guests
