headlight switch
headlight switch
is there a way of removing the headlight (on/off) switch?
I've tried to get a couple from the breakers but seem to damage them.
Mines playing up and I need to change it, when on sidelights only the near side lights come on, and on dip the dashboard lights dont illuminate unless I whack the switch several times!
stuy
I'm only going from Haynes here, but........
Pull the switch out slightly and insert a small screwdriver or rod through the hole in the bottom of the switch knob to depress the knob retaining clip.
Pull the knob from the switch.
Press the 2 now exposed switch securing clips towards the centre spindle, then pull the switch from the facia and disconnect the plug.
It's a bit clearly with the pictures in front of you, but hope it helps a bit.
Paul
I've got one you can have for £5 delivered if you are struggling. You need to remove the section of dash that contains the switch first - unfortuunately that means taking the sterring wheel cowling and section below the speedo out. The slide a thin flat bladed screwdriver down each side of the switch (from the back where the electrical connections are) it then just pops out.
imcsherry
thanks, I'm gonna have a wander again to the scrappy this afternoon so I'll have another go with them instructions. Would be far easier to replace the whole panel, but I cant find any l/h/d ones in the breakers!
think I'll get one ok thanks imcsherry, but if I get stuck I'll give you a shout.
(and I'll put a haynes manual on me shopping list!)
stuy
stuy
