Does Your Wheel Sit Centred?
Yeah, mine is spot on.. but I did get a new steering rack fitted and it was on the nail afterwards, before it was a couple of degrees out.
Kieran_Burns
<!--QuoteBegin-Kieran_Burns+--><div class='quotetop'>(Kieran_Burns)</div><div class='quotemain'><!--QuoteEBegin-->Isn't it 'just' a matter of adjusting the track rod ends???<!--QuoteEnd--></div><!--QuoteEEnd-->
If it is that, I'm judging by how 'just' is in apostrophes that it's not a particularly easy job then? [img]/sad.gif[/img]
Smurf
<!--QuoteBegin-jaybv6+--><div class='quotetop'>(jaybv6)</div><div class='quotemain'><!--QuoteEBegin-->It's best to get someone to do it. Preferably on a laser tracking machie to make sure that nothing else is wrong. It's not a job to be done yourself unless you have the tools to measure what you are doing.<!--QuoteEnd--></div><!--QuoteEEnd-->
Thanks mate.
The place I'm getting the wheel refurbs done (Micheldever) probably have the facility there to check it, so I'll get it done when I get round to doing those.
Thanks mate.
Smurf
Water Pump - Replace Or Not?
Thanks Kieran.
What are the usual general effects of having bad tracking?
In the same area - what are the general effects of a bad steering rack?
Smurf
Bad tracking:
pulling to one side (make sure it isn't the road camber)
excessive wear on one rim of the tyre (inside / outside), excessive wear on both is more likely due to incorrect tyre pressure
Bad Rack:
In my experience (had it a few times now...)
'notchy' steering
heavy steering
whining when turning
'loose' steering - i.e. no response to minor turns of the wheel
However they can also be accounted for by other problems (heavy and whining are sympomatic of low PAS fluid levels, notchy could be CV joint / wishbone bush etc)
Hope this helps!
Bad Rack:
'notchy' steering
heavy steering
Hope this helps!
Kieran_Burns
Smurf steering thread
Err guys,
Couldnt it be that the steering wheel may have been taken off and then put back on skewy ?
Just a thought.
Pete
Just a thought.
Pete
peter
Thanks for the explanation Kieran - much appreciated.
Pete - that was another thing I was thinking of. I think I'll get the tracking checked anyway as some of the other symptoms Kieran has listed are also valid for me at the moment.
If all else fails I'll take the wheel off and sit it back straight. It's just having to take it to Vauxhall and pay them £20 for them to reset the airbag fault it'll flag up which is the pain of doing that [img]/sad.gif[/img]
Smurf
<!--QuoteBegin-Smurf+--><div class='quotetop'>(Smurf)</div><div class='quotemain'><!--QuoteEBegin-->If all else fails I'll take the wheel off and sit it back straight. It's just having to take it to Vauxhall and pay them £20 for them to reset the airbag fault it'll flag up which is the pain of doing that [img]/sad.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
***Warning*** Stop right there. I would not advice removing an Airbag steering wheel yourself. Only do so if you are sure that it will not go off. The main thing is to disconnect the battery before you even attempting to do anything with the steering wheel. You then need to disconnect the connection for the airbag trigger.
I doubt it very much if the steering wheel has beenremoved and replaced incorrectly.
jaybv6
