Brake Recommendation Pls
by STEVA » Wed Nov 02, 2005 4:52 pm
<!--QuoteBegin-Alcofrolic+--><div class='quotetop'>(Alcofrolic)</div><div class='quotemain'><!--QuoteEBegin-->Think im gonig to go for Black Diamond Disks and pads. They seem very reasonably priced.<!--QuoteEnd--></div><!--QuoteEEnd-->
Go for it ive got them on mine and they are spot on [img]/biggrin.gif[/img]
Steva
My Turbo
My Turbo Rebuild Thread
steva@clubcalibra.net
by MickM » Wed Nov 02, 2005 5:48 pm
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->green stuff really start to work above 300degrees C<!--QuoteEnd--></div><!--QuoteEEnd-->Green Stuff are designed to work from cold are they not..? I though it was only Red Stuff and Yellow Stuff that had a higher than ambient start range..? That said, I know a lot of people who complain that they don't work from cold.
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Think im gonig to go for Black Diamond Disks and pads. They seem very reasonably priced.<!--QuoteEnd--></div><!--QuoteEEnd-->I've got BD's on mine (X-drilled and Grooved) and they are okay. The BD Predator pads have caused me some troubl though. The braking is fine but they clunk around in the caliper under braking as they are slightly too small. Also, when I eventually removed them the friction material had completely come away from the backing plate on one of them.
Whilst you are at it I highly recommend braided hoses. You will notice more difference with the hoses than you will with the discs and pads and the pedal will feel much more solid. I've got them on the bike too and the feel is so much better...
MickM
by dicky » Thu Nov 03, 2005 4:06 pm
I have green stuff pads and they do need to warm up a bit to get working i found, my mate also says the same who has greenstuff on his elise.
dicky
by Toddy » Sun Nov 13, 2005 6:54 pm
I have BD grooved disc's and BD pads, the best thing I did was to fit braided hoses, what a difference:D
Toddy
by King Calibra » Sun Nov 13, 2005 6:57 pm
<!--QuoteBegin-swchoi+--><div class='quotetop'>(swchoi)</div><div class='quotemain'><!--QuoteEBegin-->lol, I use engine brake a lot, and I hate slow driving.<!--QuoteEnd--></div><!--QuoteEEnd-->
I don't unless I have to, Brakes are cheaper and alot easier to change than a clutch!
BTW, I use ATE Oval Slotted discs all the way around, and OEM Pads, Have NEVER had brake fade.
King Calibra
by swchoi » Fri Nov 25, 2005 2:56 pm
You are quite true, as I need to change my clutch at the moment. But,hey where the all fun driving comes from
swchoi
by johnny_adidas » Fri Nov 25, 2005 3:20 pm
best place to get a set of braided hoses? and roughly how much?
johnny_adidas
by swchoi » Fri Nov 25, 2005 6:01 pm
I got one from LMF, but you can try rally design.
swchoi
Previous
