What tyres do you recommend
I had Falkens on my old 16V, took it to the garage to get some new ones fitted which I'm glad I did as when they took the Falkens off we seen that they had spit/cracked and generally fallen to bits on the inside. There was loads of rubber that had come away from the inner wall. Was lucky not to have a blow out:mad:
This was on two of them as well:frown:
Toddy
<!--QuoteBegin-Toddy+--><div class='quotetop'>(Toddy)</div><div class='quotemain'><!--QuoteEBegin-->I had Falkens on my old 16V, took it to the garage to get some new ones fitted which I'm glad I did as when they took the Falkens off we seen that they had spit/cracked and generally fallen to bits on the inside. There was loads of rubber that had come away from the inner wall. Was lucky not to have a blow out:mad:
This was on two of them as well:frown:<!--QuoteEnd--></div><!--QuoteEEnd-->
Were they inflated enough?
Calibra Turbo LE 28
Sounds like they were run flat at some point [img]/sad.gif[/img]
Rusty_CallyT
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->Sounds like they were run flat at some point [img]/sad.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Nope, check the pressure on my tyres every couple of weeks. Mechanic thought I had a dodgy one until we seen the same had happened on another one of them:frown:
Toddy
<!--QuoteBegin-Dan_85+--><div class='quotetop'>(Dan_85)</div><div class='quotemain'><!--QuoteEBegin-->i had some Avon ZZR's on my 17's - amazing!
directional V shape made them amazing
good wearing aswell<!--QuoteEnd--></div><!--QuoteEEnd-->
sorry But im my humble opinion i reckon AVON should stick to selling make up.
fcuking shti wnak
fcuking shti wnak
FatLadZ
from my experience in my mr2 (grip v important there) the best tyre you can get has to be goodyear f1s but they lasted about 4k miles! then i used toyo t1-rs which werent as good in the wet but were decent in the dry, they lasted 7k, i then tried avons which seemed better than the toyos in the wet but i didnt like them at speed, seemed to be a lot noiser, but they were the cheapest and lasted over 9k.
BUT STAY AWAY FROM NANKANGS! these are ditch finders, the worst tyres i have ever had, were on the alloys when i bought them and didnt even do 100 miles before i got rid of them, maybe on an escort or summit simlar they would do but on an mr2 a difference in tyre makes a hell of a difference compared to other cars.
houston
Yer iv had avon, rubbish.
Im on Pirelli P6000's which are ok, but arnt that great in the wet.
Toyo Proxies are good for the price but do wear quick.
My choice *budget excluded* would be yokohamas [img]/smile.gif[/img]
You might find these usefull too...
<a href="http://www.blackcircles.com/" target="_blank">http://www.blackcircles.com/</a>
<a href="http://www.mytyres.co.uk/" target="_blank">http://www.mytyres.co.uk/</a>
Add_Gee
