cannot remove rear spring!
by Molecule » Tue Feb 14, 2006 9:11 pm
there is on the front ones, I am sure I saw it on the rear:
75261/front
Molecule
by Fortuna » Wed Feb 15, 2006 8:31 am
This thread is worrying me. I have a set of new lowering springs ready to go on my V6 in the spring/summer. I am dependant on the supplier getting it right and clearly Molecule's has not!! I've NEVER seen a Cally look so high! Fraz is there anywhere we can look up spring heights, standard and lowered? My new springs are unbranded but printed with "BOGE 60-8010 REAR (and FRONT)
Fortuna
by Fraz » Wed Feb 15, 2006 12:40 pm
well its the right springs for your car 30mm drop
<a href="http://www.zf-trading.co.uk/owx_medien/media224/22458.pdf" target="_blank">Boge springs</a> page 88 to save you looking
by Fraz » Wed Feb 15, 2006 12:44 pm
just noticed you said rear AND front
front part No should be 25-388-0
and sorry Molecule cant find any info on yours
by Molecule » Wed Feb 15, 2006 2:11 pm
been talking to the supplier, the springs are the right one they said, the numbers on them are correct ( 75860/rear and 75261 front ). I told them it does not look right and the rubber seating on the car are way too small and the spring could move about. Three coils touch each other and the car sits too high.
Molecule
by Stupink » Wed Feb 15, 2006 2:47 pm
From that picture i would say its the bump stops that are stopping hte car drop.
the bump stop is probably designed for std height??
by TommyC » Wed Feb 15, 2006 2:50 pm
Molecule,
My car is lowered 35mm on an Apex kit. (the car is sitting on a highly camberd road, but when on the flat it looks a tiny bit lower.....honest!!)
Three of the coils touch on my springs touch and they will move around a tiny bit when theres no weight on the suspension. But i've never had any problems with them in the three years they've been fitted to the car!!!
From your pictures i can't see why the car is still so high with lowering springs fitted. The springs look just like mine, although i fitted mine the other way round (but the writing on them was still the right way up).
It might be worth your while taking the spring out, re-fitting the wheel and moving the suspension arm through it's full arc. Just to make sure that there's nothing stopping it moving right up.
Does the shock absorber move ok??
TommyC
by Molecule » Wed Feb 15, 2006 3:04 pm
will have a go. Thanks.
And yes, seems the way to fit these progressively wound springs is to put those three coil at the top.
Molecule
by TommyC » Wed Feb 15, 2006 3:15 pm
<!--QuoteBegin-TommyC+--><div class='quotetop'>(TommyC)</div><div class='quotemain'><!--QuoteEBegin-->It might be worth your while taking the spring out, re-fitting the wheel and moving the suspension arm through it's full arc. Just to make sure that there's nothing stopping it moving right up.
Does the shock absorber move ok??<!--QuoteEnd--></div><!--QuoteEEnd-->
You could take the spring out, bolt the shock back on and use a trolley jack to move it up (the easiest place would be on the bottom of the shock mount right at the back of the suspension arm). That way you'd be checking both at once.......
Just be careful if it does stop cos you could end up jacking the car up off the axle stands and making it unstable!!!!!
TommyC
by Molecule » Wed Feb 15, 2006 5:53 pm
got 17" wheels -( 205 40 17 ) and the gap from the arch to the outer tyre is 3 inches
anyone got same setting to compare?
Arms can move ok
Molecule
by Fortuna » Wed Feb 15, 2006 8:55 pm
Frazer, Thanks very much.
Molecule, Good luck mate
Fortuna
by TommyC » Thu Feb 16, 2006 3:38 am
<!--QuoteBegin-Molecule+--><div class='quotetop'>(Molecule)</div><div class='quotemain'><!--QuoteEBegin-->got 17" wheels -( 205 40 17 ) and the gap from the arch to the outer tyre is 3 inches
Arms can move ok<!--QuoteEnd--></div><!--QuoteEEnd-->
Mine are 17's with 205/40 tyres. Gap is around an inch (ish).
How far do the arms go before they stop?? Have you tried the setup without the powerflex bump stops??
Mine has springs and shocks, powerflex rear anti-roll bar bushes and four irmscher camber correction bushes. That's all that has been messed with on the back suspension of my car.
Do you think they may have sent you some cavalier rear springs instead?? For a car without Independant Rear Suspension (IRS)?????
TommyC
by Molecule » Thu Feb 16, 2006 10:58 am
1 inch, wow.
Yesterday I stripped it all off 3 times, so good at it now, and tried to move the trailing arms all the way up ( without spring or bumpstop ) and nothing stop them. The *** is still up in the air. I got koni ssk kit, the shocks are ok. Had to refit everything as I need the car today and going away for 5 days. Gonna have to wait now. The suppliers have been helpful and can sort something out when I return. I sent them pics and said it is not right.
Thanks for all the help guys
will post the progress next week
Molecule
by pr0xZen » Wed Mar 01, 2006 8:38 am
This is odd. I've got the same set of springs that you do - and it only took about one day to seat at exactly -35mm. Are you sure your koni's are not set to some insanely stiff properties?
pr0xZen
by Molecule » Wed Mar 01, 2006 8:30 pm
What sort of gap do you get between arch and wheel?
Molecule
