Big Brake Issue - Please help
I would advise changing the brake fluid if the cars been sat around for a while, you might find moiture has gotten in there and that wont help things...
The grinding noise could be the dust cover behind the discs rubbing on the discs, ive had that problem before when ive played around with the brakes, just get the car up in the air, take the wheel off and spin the disc, you'll soon track down where the noise is coming from...
I know how you felt about the seized bolts, you should invest in a blow torch, you can get them pretty cheap, got mine for £9.99 from halfords, will come in handy for any other things you might need to change later on... If you plan on doing any suspension work then GET ONE!!!
