Things can only get better
Re: Things can only get better
by Robs-se » Wed Sep 29, 2010 7:58 pm
Fraz wrote:rechts = right
links = left
die Vorderradbremse = the front brake
das Heckteil = the back
so your pipe thats dry is the back right and the front left , so looks like your master cylinder again
Yep so going to change it at the weekend
by Fraz » Wed Sep 29, 2010 7:59 pm
oh good site for all them German car terms
http://cardict.de/
by Robs-se » Wed Sep 29, 2010 8:03 pm
save us getting the old english/german school dictionaries out
by Robs-se » Sat Oct 02, 2010 4:11 pm
New master cylinder now fitted all brakes bled BUT the first press of the pedal goes along way down before it stops. Second press is ok, so is there any other way air can get in, my pipes are ok no leaks. beginning to loose patients with it now :(
by v6 steve » Sat Oct 02, 2010 5:34 pm
it might just need bled again remember the amount of air that you have pumped into it over the last week or so i would bled it again
by Robs-se » Sat Oct 02, 2010 8:45 pm
Could be a while in this weather :lol:
Re: Things can only get better - sorted
by Robs-se » Sat Oct 09, 2010 7:44 pm
Have finally cracked it :clap: :dance: . managed to get the seized bleed nipple undone on the passenger front caliper and bled it and the other 3 (being 4 pot calipers there 4 bleed nipples per caliper). Allc sorted now and stopping on a sixpence again. I'm happy :D
by tazz666 » Sat Oct 09, 2010 7:45 pm
pleased for yah mate :D
by Robs-se » Sat Oct 09, 2010 7:50 pm
Cheers Tazz, one off the list now loads still to go
by v6 steve » Sat Oct 09, 2010 7:53 pm
good brakes are a most if you ask me, well done
by Robs-se » Sat Oct 09, 2010 7:54 pm
I have learnt never to trust brakes 100%, always err on the side of caution when braking ie never slam them on at the last minute as they may fail anytime
by vinny_69 » Mon Oct 11, 2010 2:09 pm
well its about time Rob
vinny_69
by Fraz » Mon Oct 11, 2010 2:53 pm
Robs-se wrote: managed to get the seized bleed nipple undone on the passenger front caliper
Erm I dont recall you ever saying you had a problem with the front, I recall some issue with the rear not getting fluid through
Previous
