ABS Help!!
ABS Help!!
Driving along I suddenly noticed my ABS light came on :confused: , didnt know why so I stopped, called a mate who had no ideas, started her up again and no light!!
Anyone help? Is it simple (not costly), like fluid or is it dangerous?
Hope someone can help, its an 8v Calibra
Tigerbuc2004
Just check the fluid level, then see how it goes. it might never come on again, or it might be an early warning that you're about to loose a sensor from a break in the wire or poor reading etc.. nothing to worry about so long as your brakes work ok tho, you'll never loose your breaking system when the abs trips out, just loose the ABS and have to go back to cadence braking etc etc...
mines been doing for a couple of months mines a 8v to,have u checked to see if there is any codes on the ecu,it will flash 12 3 times then the problem codes,ive got code 37 and i dont know how to fix it,it sounds like the same prob as mine because when i turn it off and then on again my abs light doesnt come on again for ages,
there is a how to do it on <a href="http://www.topbuzz.co.uk" target="_blank">www.topbuzz.co.uk</a> hope this helps,
jay
jay
jayl645
Users browsing this forum: Google [Bot] and 10 guests
