Wonky
Wonky
Right where to start explaining....
The steerings alwayz been slightly off centre, so i had it tracked (about 6 months ago) it was still wonky so he tracked it slightly off to sort it temporary. Got round to changing the bottom arms and track rod ends and drop links. Got it tracked and its still off. (about 30 degrees right)
If i took off the wheel and moved it some spligns over would that sort it or if they tracked it again would I need to do that again?
They did it about 6 months ago and it was off centre then. Thwy then tried doing it a few times more and it did the same. Since then I've had the bottom arms renewed, track rod ends and antiroll bar drop links. Got it tracked up and it's still off. Think I'm going to try somewhere else just to see, but I dont think it will do much, because if their machine didnt work it would have been picked up on by now I would have thought. [img]/sad.gif[/img]
