Tires wear
Tires wear
by O2re » Mon Jul 18, 2005 5:13 pm
Rear tiers wears out inside , got Camber kit , lowered 40 , 215/35/19 is expencive
What to do ? anyone ?
O2re
by Tim2001 » Mon Jul 18, 2005 5:23 pm
check that your not rubbing on cornering for a start followed by getting the tracking and alignment checked out
Tim2001
by daddycool » Mon Jul 18, 2005 7:23 pm
I presume from your previous posts/pics that the car has been jigged!
Did they do it correctly?
Get the camber/toe/etc checked and then take it from there.
daddycool
by joeraz » Mon Jul 18, 2005 8:00 pm
were do you get the camber kit from?
joeraz
by daddycool » Mon Jul 18, 2005 8:18 pm
Wallace do an adjustable kit or you can by fixed Irmscher correctors from your local Vx dealer.
Or you could do a SEARCH for Fatladz DIY solution [img]/smile.gif[/img]
There, I've done it for you [img]/smile.gif[/img] <a href="http://www.clubcalibra.net/forum/articles.php?action=viewarticle&artid=25" target="_blank">http://www.clubcalibra.net/forum/articles....rticle&artid=25</a>
daddycool
by damon » Wed Jul 20, 2005 12:09 pm
Great, cos I need to fix my camber angle too. Its the first thing im doing to my car.
Will it make any difference performance wise? Will it effect handling for the better or worse or just fix the un-even tyre wear?
damon
by O2re » Mon Aug 08, 2005 12:10 am
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->I presume from your previous posts/pics that the car has been jigged!
Get the camber/toe/etc checked and then take it from there.<!--QuoteEnd--></div><!--QuoteEEnd-->
Yes jigged , done it my self ,so it`s good as new
Camber kit did i buy "down under" (Astralia)
can adjust alot but not enought in correct direction
i guess the only way is to rebuild rear frame
if i find a solution i`ll post it
thanks to everybody posting , nice to get some comfort
meantime i`ll have to spend all my $on tiers
O2re
by daddycool » Mon Aug 08, 2005 12:38 am
Did you follow the link I posted earlier in the thread?
daddycool
by O2re » Mon Aug 29, 2005 9:16 pm
<!--QuoteBegin-daddycool+--><div class='quotetop'>(daddycool)</div><div class='quotemain'><!--QuoteEBegin-->Did you follow the link I posted earlier in the thread?<!--QuoteEnd--></div><!--QuoteEEnd-->
Yes , i maybe want to cut off and move the plates , instead of just drilling a new hole , i`v got a 60mm drop , don`t know if this mod is enough
but i think so , because i also have camber kit
i see you run on 19"`s , any prob. ? your wheel ali.... measure figures?(bad language sorry)
any calibra`s on airbags around ? guess this is moore common on the Cadillac catera (same rear frame)
O2re
