Track rod ends
Track rod ends
by chas27 » Sat Jul 30, 2005 2:59 pm
After putting new 17" wheels on decided the tracking was out but when i took to tyre shop they tell me the trackrod ends are completely seized.
What a bummer its one thing after another with Calibra's.
Anyway does anyone know if its a big job or what?
Could it be done or does it need to go to proper garage?
chas27
by ROG » Sat Jul 30, 2005 3:06 pm
when i went for tracking they said that mine were siezed, without touching them, they needed replacing!
The next day i soaked them in wd40 a few fimes, left it till the next day and cleaned them up with a cloth, then went somewere else and because they looked recently fitted they just did the tracking woth no problems
ROG
by chas27 » Sat Jul 30, 2005 3:16 pm
yes i did think i might get away with giving em a good soak in wd40, they ll probably loosen if left overnight.
chas27
by Fraz » Sat Jul 30, 2005 3:40 pm
the main problem is the actual 13mm locking bolts on the track rod ends will snap off. I tried to loosen mine of and one broke. I just replace both sides
easier if you remove both the arms from the actual rack and then have them in a vice, It took me about two hours from start to finish to do both sides
by Animal » Sat Jul 30, 2005 6:53 pm
How do u get the arms off the rack?
by Fraz » Sat Jul 30, 2005 9:32 pm
two 15mm bolts right in he middle of the rack you need to take the locking tabs off though first
by Cheater2k » Wed Aug 24, 2005 10:46 pm
aye, had to have this done to my old cally, and its been done to my turbo as well, cover them in copper greese when you put them back together [img]/smile.gif[/img]
Cheater2k
by Naz » Wed Aug 31, 2005 12:06 am
If you take it to a garage then they can nseize them normally. You can heat them up gently and use WD-40 at the same time to unseize them. Its do able but some people can't be arsed and people like Kwikfit won't allow their 16yr old mechanics to tuch the ecetyn torch.
Naz
by Cheater2k » Wed Aug 31, 2005 7:49 am
It is much easy to take the whole steering arms off though and do it on the bench, this prevents you from bending the arm then [img]/smile.gif[/img] copper grease it all up, and you dont get the problem again really
Cheater2k
by Fraz » Wed Aug 31, 2005 12:53 pm
or you put them in a workmate and use one of them things from B&Q gas butane type burners ....just enough heat to slacken them off but it dont get as hot is your using Oxy/Ethylene
by j4mes » Wed Sep 07, 2005 12:19 pm
how much are replacement arms?? are they supposed to have a slight bend in them, or be dead straight
j4mes
by trev150 » Wed Sep 07, 2005 12:29 pm
This is a common fault on Cavaliers aswell. Been through loads of them.
Can be b@st@rds to get at. But shouldn't be a expensive job.
Users browsing this forum: Bing [Bot] and 16 guests
