Knocking noise drivers footwell
by mavar1ck » Sat Aug 20, 2005 10:21 am
All solved thanks
mavar1ck
by dj_smurph » Sun Aug 21, 2005 10:51 am
possible anti-roll bar link or cv joint is knacked, light does not come on for ac unless there is enough pressure in the system you can get the gasses from halfords but i dont know where to put it in
dj_smurph
by debowen » Sun Aug 21, 2005 2:54 pm
Cheapest check is the CV joint. But auxillary belts can also cause the problem. Get a spray bottle of water and spay the belts while the engine is running. If the noise disappears, wait for them to dry and apply belt dressing "carefully" to shut down the noise.
debowen
by mavar1ck » Sun Aug 21, 2005 10:07 pm
Only makes a noise when turning and pulling away, if it was the roll bar would it be a knock knock knock etc or just a couple of knocks?
mavar1ck
by mavar1ck » Mon Aug 22, 2005 10:16 pm
Thanks all for your help was the CV joint, all better now.
mavar1ck
