Is my car lowered or standard?
Come on guys, slap a tape on it for me.
by Heather » Sat Aug 20, 2005 5:50 pm
One of my rear springs has broken and woundered if you'd mind measuring from the top of the wheel arch to the ground for me front and back to see if mine are lowered.
I don't want to put standard springs on and find out that they should be lowerd. (may just go for a full set of -40 G-max anyway)
Thanks
Heather
Heather
by davefly76 » Sat Aug 20, 2005 7:43 pm
what colour are your springs?
most lowered springs are usually red or yellow, the standard ones are black.
[img]/smile.gif[/img]
davefly76
by Heather » Sat Aug 20, 2005 7:44 pm
The're black
Heather
by daddycool » Sat Aug 20, 2005 8:59 pm
My Eibach -35s are also black.
daddycool
by Heather » Sat Aug 20, 2005 9:06 pm
Would you mind measuring from the road to the wheel arch to compare
Heather
by jonnyboy » Sat Aug 20, 2005 9:16 pm
Measure from the centre of the wheel or the hub as different size tyres will give you different floor - arch heights.
jonnyboy
by Heather » Sat Aug 20, 2005 9:19 pm
Thanks, mine is 360mm from centre of wheel to top lip of arch where it sticks out
Heather
by EXCALLYT » Sat Aug 20, 2005 11:46 pm
<!--QuoteBegin-Heather+--><div class='quotetop'>(Heather)</div><div class='quotemain'><!--QuoteEBegin-->One of my rear springs has broken and woundered if you'd mind measuring from the top of the wheel arch to the ground for me front and back to see if mine are lowered.
Thanks
Heather<!--QuoteEnd--></div><!--QuoteEEnd-->
I have two cally turbo spings, they are free if you want them...
email me <a href="mailto:yunisaz@hotmail.com">yunisaz@hotmail.com</a>
EXCALLYT
by Heather » Sun Aug 21, 2005 12:23 am
Thanks, will they fit & where are you (midlands here)
Heather
by daddycool » Sun Aug 21, 2005 12:50 am
Heather, it would help if you mentioned which model Cally you have as different models had different suspension as standard.
IMHO you should get a full set of lowered springs and not just renew the broken one/s.
daddycool
by Heather » Sun Aug 21, 2005 10:17 am
I've only got the 8V (sorry thought I'd put that)
If the springs are standard I may just change the back ones but if I fit lower ones I will do them all.
I have been quoted £32.61 +VAT EACH for standard springs and £81 +VAT for a lower set from the same garage. Just worried about speed bumps etc. (Hubby had an Arkley lowered 3" and we couldn't go any ware where the lines were too thick on the road)
Heather
by daddycool » Sun Aug 21, 2005 4:59 pm
<!--QuoteBegin-Heather+--><div class='quotetop'>(Heather)</div><div class='quotemain'><!--QuoteEBegin-->Hubby had an Arkley lowered 3"<!--QuoteEnd--></div><!--QuoteEEnd-->Cool!
But I'm sure you will be OK with -35mm springs on you Cally. They are also a bit stiffer so don't 'dip' as much when going over the dreaded speed bumps [img]/smile.gif[/img]
daddycool
by knightonahorsie » Sun Aug 21, 2005 5:18 pm
I have a brand new boxed set of G-max springs for the 8v that I am asking £40 + postage (will let you know the postage cost)
knightonahorsie
by Phantom » Mon Sep 05, 2005 1:24 pm
<!--QuoteBegin-knightonahorsie+--><div class='quotetop'>(knightonahorsie)</div><div class='quotemain'><!--QuoteEBegin-->I have a brand new boxed set of G-max springs for the 8v that I am asking £40 + postage (will let you know the postage cost)<!--QuoteEnd--></div><!--QuoteEEnd-->
now thats a bargain if ever I saw one [img]/wink.gif[/img]
Phantom
Users browsing this forum: No registered users and 137 guests
