Brake Recommendation Pls
by Alcofrolic » Tue Oct 11, 2005 10:21 pm
HI,
Can someone recommend a good make of brake pads and discs, I know nothing about them so not sure where to look.
The ones I have on at the moment are like the cheapest make ever and squeek like mad. Id really like some decent ones.
Thanks in advance.
Alcofrolic
by nicc from notts » Tue Oct 11, 2005 10:32 pm
hi ya. try to buy spares from a motor factor .. they supply garages etc. so normal they have good quality stuff as standard. also get a tube of copper grease. put it on the edeges of the pad that touch the caliper and also on the back of the pads. a blob about smartie size rub over the back. this helps pads to slide and should stop the brake squeel. clean the claiper with a wire brush before fitting the new pads. hope this helps.
nicc from notts
by Alcofrolic » Tue Oct 11, 2005 10:48 pm
Hi thanks for your reply..
I took the car in to a garage and they did all that but it hasnt helped, they are still squeaking like mad. Its just cos they are a cheap make.
Forgot to mention what car i had, in case that makes a difference. Its a 16v 1994 2.0
Thanks
Alcofrolic
by nicc from notts » Tue Oct 11, 2005 10:53 pm
did they just do the front brakes??? calibras have discs and drums on the rear. it could be the rears that are making the noise
nicc from notts
by Animal » Wed Oct 12, 2005 12:05 am
Green stuff pads are top pads IMO! [img]/biggrin.gif[/img]
by Cheater2k » Wed Oct 12, 2005 12:30 am
Geniune vaux pads are alot better than greenstuff, ive tried both, had fade badly with green stuff, never had it with vaux.
Cheater2k
by kev208 » Wed Oct 12, 2005 7:52 pm
dont the brakes have anti squeal rubber backs or something like that. also black diamond are supposed to be good.
kev208
by dj_smurph » Sun Oct 16, 2005 9:37 am
black diamond drilled and grooved front and rear with greenstuff can brake damn hard, stop real fast, never had the abs kick in and never had fade, greenstuff will only perfom 100% on performance discs because of the extra heat generated green stuff really start to work above 300degrees C
dj_smurph
by swchoi » Tue Oct 18, 2005 11:36 pm
contact LMF for a big brake conversion, it is so good that my car now stops whenever i want to. Green stuff pad are not bad, it has really long life. I used around 3years without changing it. I am not sure about the fading caused by green stuff as I never had problem using it.
swchoi
by Cheater2k » Tue Oct 18, 2005 11:38 pm
swchio, if your brakes last you 3 yrs your a very light braker or slow driver, lol
im going through a few sets of pads a yr, no matter what make i use, but only vaux stops fade.
Cheater2k
by swchoi » Fri Oct 21, 2005 4:29 pm
lol, I use engine brake a lot, and I hate slow driving.
swchoi
by dicky » Fri Oct 21, 2005 10:23 pm
I had green stuff pads along with Brembo discs but were not drilled or grovved on my calibra which i had fitted and they were very good, they only faded at 120mph whilest driving on a test track.
dicky
by midscalibra » Wed Nov 02, 2005 6:19 am
fitted all new disc and pads on the front from vx dealer, only £70 the lot. i'm looking at getting new calipers now.
midscalibra
by Fostersice17 » Wed Nov 02, 2005 1:14 pm
I have Tarox G88 discs all round with green stuff pads all round.Very happy with them.
Fostersice17
by Alcofrolic » Wed Nov 02, 2005 2:05 pm
Think im gonig to go for Black Diamond Disks and pads. They seem very reasonably priced.
Alcofrolic
