Stearing Lock
Stearing Lock
The last couple of weeks I have noticed that my stearing lock is a nightmare to get undone when I put the key in and try turn it! Any Ideas as to what it might be and how it could be fixed?
clinty
Kieran_Burns
<!--QuoteBegin-clinty+--><div class='quotetop'>(clinty)</div><div class='quotemain'><!--QuoteEBegin-->The last couple of weeks I have noticed that my stearing lock is a nightmare to get undone when I put the key in and try turn it! Any Ideas as to what it might be and how it could be fixed?<!--QuoteEnd--></div><!--QuoteEEnd-->
Its probably because the barrell is a bit worn.
Cheapest is to get the barrell out and then remake the lock to see if it cures the problem. If not, have a new key made for you.
The most expensive option is to have the whole lock set changed( thats boot, doors and ignition).
Naz
Do you always enable your steering lock when you leave the car?!!
When you put the key in, and the steering lock is enabled, you won't be able to turn the steering OR the key. Depending on the direction you used to lock the steering, you have go the same way only slightly and then try turning the key. That should disable the lock as it takes the load off the nutch.
Naz
dj_smurph
