bloody koni kit
bloody koni kit
slight prob which is getting on me ****,my springs are clunking when moving the steering whell at slow speed or stationary. is there anything i can do,or do i just have to bear with it, bearing in min having 18's on 205/35 dont help i guess
Welsh_Andy
<!--QuoteBegin-nigescalli+--><div class='quotetop'>(nigescalli)</div><div class='quotemain'><!--QuoteEBegin-->had this prob with konis on a corsa and it turned out to be a knackered shock<!--QuoteEnd--></div><!--QuoteEEnd-->
bloody hope not tis less than a yr old:eek:
but has been quiet for ages,but hit a nasty pothole other day and now is worse than ever:sob:
Welsh_Andy
<!--QuoteBegin-se6+--><div class='quotetop'>(se6)</div><div class='quotemain'><!--QuoteEBegin-->I had similar on my car, wasnt Konis, but was the strut top worn. When the car was jacked up the whole leg would move quite a bit if you wiggled the wheel from top to bottom. I had a noise from the springs at slow speeds whilst turning.<!--QuoteEnd--></div><!--QuoteEEnd-->
what is the fix to that?
Welsh_Andy
bloody potholes. i had mine running perfect after changing the tie rod ends. 1 or 2 big potholes later n its back grinding as bad as ever. the guy who did the tracking a hile back said the strut was damaged doh so maybe its as u suggest. bloody 18s. ill eventually get round to changing it.
johnny_adidas
<!--QuoteBegin-AndiSe5+--><div class='quotetop'>(AndiSe5)</div><div class='quotemain'><!--QuoteEBegin-->I have just had this problem after i fitted my konis, at low speed i got creking but sounds like its just from the nr side.
To cold and wet to investigate at the moment.<!--QuoteEnd--></div><!--QuoteEEnd-->
same side as me,although mines more a clunking
Welsh_Andy
has anyone rectified this problem yet, ive just fitted Koni adjustables and am getting the same problem, can be really load at times, just had them apart to see if i could see a problem but everything looks ok, the wheel does move forward though when its jacked up as if the whole strut wasnt seated correctly ?! doing my head in now and its gotta be really load outside the car ?!
cali steve
