Cav springs on a calibra?
by Phil » Tue Dec 06, 2005 2:42 pm
Hi,
I'm sure this has been asked a million times, so I apologise now!!
Do Cavalier springs fit onto the Calibra as a straight swap?
Some advertised say not for 2.0l model? Will these not fit the 2.0l 8v Calibra either?
Please help me!!!!!!!!
Cheers.
Phil
by thecrow » Tue Dec 06, 2005 10:21 pm
Fronts will, rears will also but they car will sag at the back IIRC.
Basically you'll be ok for the front, but the rear won't be level.
thecrow
by AndiSe5 » Tue Dec 06, 2005 10:44 pm
You will be ok if the springs are off a caviler with IRS. ie gsi and 4x4.
AndiSe5
by Phil » Wed Dec 07, 2005 10:38 am
So a description like this could mean they fit???
Front and rear 35mm lowering springs for Mk3 Cavalier and Vectra (not 2.0Ltr) models.
Made by H & R springs, new in box never been fitted.
What's IRS?? Sorry to be thick!!
Phil
Oh Independent Rear Suspension!!
It's too early!!!!
Phil
by Phil » Thu Dec 08, 2005 11:13 am
Okay, urgently....
The guy has contacted me back, and I have confirmed that the springs were bought for a 1.8 vectra.
He said that it stated on the order form that they also fitted the cav, but not 2.0L
So will these work?
Also, I had severe arch rubbing on a 40mm drop, does a 5mm difference to 35mm drop make much difference or will it still rub do you think.
Many thanks everyone!
Phil
Phil
by j4mes » Thu Dec 08, 2005 12:38 pm
the 1.8 had a solid rear bar, so dont think that they will fit
j4mes
by Phil » Thu Dec 08, 2005 4:31 pm
Even the vectra? The bloke seemed to think it was IRS.
Anyway price gone up to far now, so it's back to the searching!
Plus I think I'd be happier with a 30mm drop only.
Thanks for your help though.
Phil
by j4mes » Thu Dec 08, 2005 5:17 pm
i'm looking for a 30 to 40 mm drop too. so let me know if you see any on ebay and i won't go for the same ones as you
j4mes
