nasty knocking in reverse
by j4mes » Wed Dec 07, 2005 10:55 am
right when i reverse on full lock i get a horrible knocking noise. i thought this was the wheels, so i made some tight fitting spiggot rings. and this hasn't helped at all.
j4mes
by SukySaggi » Wed Dec 07, 2005 12:02 pm
Do you also get the knocking on full lock while going forward?
SukySaggi
by j4mes » Wed Dec 07, 2005 12:14 pm
nope. thats the wierd thing
j4mes
by SukySaggi » Wed Dec 07, 2005 2:22 pm
Does it happen when you reverse without full lock? If it does then that could be something wrong with the gearbox. Is it a constant knocking or just one knock.
SukySaggi
by j4mes » Wed Dec 07, 2005 2:40 pm
its only on full lock.
j4mes
and its contstant.
j4mes
by SukySaggi » Wed Dec 07, 2005 3:55 pm
Full lock both sides, ie left and right or just one side.
SukySaggi
by j4mes » Wed Dec 07, 2005 3:56 pm
i think i have only gone left full lock, i will have to try the other way
j4mes
by SukySaggi » Wed Dec 07, 2005 4:06 pm
If it is just one side, check the wishbone rubbers, the bolts on the anti roll bar and the top suspension mount rubbers (bushes/donughts?) and the bearing that is inside them.
SukySaggi
by j4mes » Wed Dec 07, 2005 4:09 pm
what would you say if it was happening both ways??
j4mes
by SukySaggi » Wed Dec 07, 2005 4:14 pm
<!--QuoteBegin-j4mes+--><div class='quotetop'>(j4mes)</div><div class='quotemain'><!--QuoteEBegin-->what would you say if it was happening both ways??<!--QuoteEnd--></div><!--QuoteEEnd-->
"oh balls!"
The only thing I can think of is one of the engine mounts may have gone. (but I'm clutching at straws now :frown: )
SukySaggi
by SukySaggi » Wed Dec 07, 2005 4:17 pm
Check power streering level as well. (really clutching at straws now.)
SukySaggi
by j4mes » Wed Dec 07, 2005 4:23 pm
replaced engine mount other week. need to renew power steering fluid. i have only noticed this noise since putting my new alloys on
j4mes
by SukySaggi » Wed Dec 07, 2005 5:04 pm
Does it do it with the old alloys, if not then it could be something to do with the offset or the width of the new alloys.
SukySaggi
by j4mes » Wed Dec 07, 2005 5:24 pm
i have put it on full lock bth ways and cant see anywhere that it would rub. i might try putting old two on the front to give it a go. i know it does not need spiggot rings. as i made some that are accurate to with in 5 thou
j4mes
