abs light brakes question
by wilza0 » Tue Dec 13, 2005 4:39 pm
right have tried to find out why the abs light comes on and goes off somtimes but mainly stays on i have found the wires to the brake pad wear sensors are split or have some how got caught in the wheel MABEY would this be the cause for the abs light to come on the dash
wilza0
by j4mes » Tue Dec 13, 2005 4:42 pm
seperate circuits im afraid
j4mes
by SukySaggi » Wed Dec 14, 2005 2:17 pm
More likely to be dirty abs sensors. Try giving them a clean and also cleaning the teeth/notches. Failing that you may need to replace a sensor.
SukySaggi
by WillsToy » Wed Dec 14, 2005 3:13 pm
Paper clip test will reveal some info that will point you in the right direction.
Remeber to do ABS one and not the engine code, different pins.
And suky's reply will fix most.
Will [img]/smile.gif[/img]
WillsToy
by j4mes » Wed Dec 14, 2005 3:59 pm
pin A and the 4 th one a long
j4mes
