shakin stevens
shakin stevens
by metal-ste » Sat Dec 24, 2005 10:02 pm
My Cally's got a buckled alloy wheel.When I first got the car ,said alloy wheel was on the front drivers side.All was fine on the test driive,it was only on my way home when I got the car up to 55+mph that there was a strong vibration goin through the steerin wheel.The next day,I put the offending alloy on the rear drivers side,took the car out and it was a lot better,I could go over 55 without the feelin my wheels where comin off!
Its been fine for months until I had to get the valve changed on the buckled alloy.Now when I get to about 55 the vibration is back only it vibrates on and off every couple of seconds or so.
So my question is, is the alloy causing the vibration or the trackin/wheel alignment or somethin more serious?
Ta for any help and merry xmas
metal-ste
by j4mes » Sat Dec 24, 2005 11:10 pm
possibly balancing. but check the bolts are tight enough. tighten them like you would a cylinder head!!!
j4mes
by Chavtastic » Sun Dec 25, 2005 10:44 am
If it's when the valve was changed, it's the balancing. They probably took some of the weights off. Take it back to the garage and get it re-balanced, or take it elsewhere for the same job.
Or better still buy a new alloy!
by Mark1 » Sun Dec 25, 2005 11:02 am
Check the tyre for bulges was well both the inner and outer sidewalls.
by metal-ste » Mon Dec 26, 2005 12:25 pm
Can you buy a single alloy or will I have to go on some kind of alloy "bargin" hunt?
metal-ste
by Mark1 » Mon Dec 26, 2005 12:32 pm
You should be able to buy just one if they are still made. What make are they?
by metal-ste » Mon Dec 26, 2005 12:43 pm
Their 18" Kahn's rs-r.If you know the ones I mean.I think their still bein made.Whould I contact Kahn or some other company?
metal-ste
by dj_smurph » Mon Dec 26, 2005 12:49 pm
r-tec in st albans is where my mate got his a few years ago
dj_smurph
