Another wheels question
by robs_cal » Sun Jan 01, 2006 12:20 pm
I know this has been asked a load of times, but I have done a search and just need a simple question answered:sleep:
Im looking at 18's for my V6 with an offset of 40 and tyre size of 215/35
Just to confirm, the PCD is 5x110mm right? I shouldn't have any rubbing issues if I fit these wheels to the standard right height should I, and what amount of lowering could I get away with?
Again, sorry to ask but I just want to check the above offset will be fine.
:thumb:
robs_cal
by Mark1 » Sun Jan 01, 2006 12:40 pm
Go for 7" or 7.5" with 8's they can rubb on full lock.
I won't go any lower than 30mm.
by Rosh » Tue Jan 03, 2006 2:17 pm
Offset is OK. As Mark said, I wouldn't go wider then 7.5".
With the correct J, you can get away with lowering up to 40mm (uprated shocks and springs).
Rosh
