How low can i go?
How low can i go?
by Robert_Dale » Thu Jan 05, 2006 11:05 am
Guys and Gals,
My new V6 need lowering big time, am going to put just springs on at the mo and in summer time when i save some cash dot he full suspension!!
but for now how low can i take it on 17"'s and wheres the best place to get springs from?
Also will it affect the automatic transmission if i lower it or will it be fine?
Rob
Robert_Dale
by Dan Willis » Thu Jan 05, 2006 11:18 am
Since you have no 4x4 you can go as low as you're brave enough to try. Hold on, that was awful English. Anyway, it shouldn't affect anything really - but you'll risk grounding the bumpers, exhaust etc; and the ride will be pretty harsh after 40mm. [img]/smile.gif[/img]
Dan
by Cozy » Thu Jan 05, 2006 11:25 am
i'd go for gmax springs lower it 40mm but you need to watch the fuel line as i've heard thats one of the things you have to look out for when lowering the v6
Cozy
by DAN » Thu Jan 05, 2006 12:06 pm
I lowered my cally -60mm on 17's, then fitted a bodykit and then couldnt drive it anywhere, but it looked nice [img]/smile.gif[/img]Image
DAN
by johnny_adidas » Thu Jan 05, 2006 12:20 pm
i know the feeling, have to plan my route wherever i go now and even at that hav more than one crack in the front splitter!!!!
johnny_adidas
by Robert_Dale » Thu Jan 05, 2006 12:42 pm
-40 it is then [img]/smile.gif[/img]
Robert_Dale
by Sackie » Thu Jan 05, 2006 1:18 pm
I know mine is a Turbo, and mine is a 30mm drop and you know how bumpy that is Rob!
You might not wanna go for 40mm, but its up to you mate!
Sackie
by hoglabs » Thu Jan 05, 2006 2:06 pm
I'd recommend Eibach V6 springs with an alleged 30 mm drop (~£150).
I have had no problems with mine apart from a tiny bit of outer wheel arch liner rub on the fronts. No probs with rubbing fuel lines and it still gets over all of the speed humps in my area without contact.
You can get away with just replacing springs and leaving the stock shocks but you really should change the shocks at the same time. If you don't fancy Konis then go for Bilstein fixed height shocks - these are a reasonable match for the Eibachs and are cheaper than Konis.
With a good set of aftermarket springs and shocks you should notice a significant improvement in V6 handling. Inevitably the ride will be slightly more harsh.
hoglabs
by Robert_Dale » Thu Jan 05, 2006 2:51 pm
yeh -35 i might go, don't want to be scraping on the floor lol
Robert_Dale
by RobbieV » Thu Jan 05, 2006 5:01 pm
Running 17's with 215/40/17 tyres and dropped on -40mm Gmax springs, no problems [img]/smile.gif[/img]
by chief » Thu Jan 05, 2006 9:16 pm
just dropped mine 40mm on gmax springs and standard shocks mate, it aint too bad ride wise, but there is a big differance. but then again it looks the mutts nutts so..................:icon_mrgr
chief
by Robert_Dale » Thu Jan 05, 2006 9:21 pm
where did you buy from guys?
Robert_Dale
by hoglabs » Fri Jan 06, 2006 12:46 am
Eibach Spring set (Pro Kit for Calibra V6 : 6530-140) ~£160
<a href="http://www.revolution.eu.com/" target="_blank">http://www.revolution.eu.com/</a>
Set of four fixed Bilstein 'Steetline' shock absorbers (OE spec) for V6 ~ £175
2 x front : PNE-3052
2 x rear : BNE-1975
<a href="http://www.performancecentre.co.uk/" target="_blank">http://www.performancecentre.co.uk/</a>
hoglabs
by dazjb » Fri Jan 06, 2006 2:12 pm
Dropped -40mm on Gmax shocks and springs, bought brand new for £200 (postage included) off Ebay. Recommended gear for the price.
I also have 17's - offset ET38 with 235 wide tyres on the rear without no rubbing, they only JUST tuck under the arches though.
dazjb
by Welsh_Andy » Fri Jan 06, 2006 3:20 pm
<!--coloro:#0000ff--><span style="color:#0000ff"><!--/coloro-->Koni<!--colorc--></span><!--/colorc--> Sport Top Adjustable Suspension Kits 40mm 215/35.18 ET38 no rubbing
were on offer at £250.
now £350
although sumit werid happened,seem the front went down as expected but rear is raised a little,looks like a dtm look,but i will have to change rear springs,but not sure wether to get 40mm or 60mm for rear as 40mm they said they supplied is high in rear
<a href="http://larkspeed.com/index.pl?c=KONIEQUIPADSUSPENKITS" target="_blank">http://larkspeed.com/index.pl?c=KONIEQUIPADSUSPENKITS</a>
Welsh_Andy
