camber correction
camber correction
by Molecule » Wed Jan 25, 2006 8:46 pm
could someone tell me what is replaced when fitting this kit? was looking at the regal site, 180......Is there any cheaper solution ( without pulling the car apart )? I will be lowering my car 35mm.
Molecule
by joeraz » Wed Jan 25, 2006 10:06 pm
summit like £16.50 + VAT per side from powerflex,,
just one bush per side
joeraz
by callyben » Thu Jan 26, 2006 12:53 am
all teh bushes are basicly the same. they are an off centre bush and as you rotate it it will adjust the camber and toe. not easy to set up.
callyben
by Molecule » Thu Jan 26, 2006 1:44 am
where do the bushes go? which ones are replaced? Is it on the lower arm?
Molecule
by sofaman » Thu Jan 26, 2006 2:42 am
Try sending a PM to roachy8734, he had a couple of sets before christmas, not sure if he still has any tho
sofaman
by Fostersice17 » Thu Jan 26, 2006 5:16 pm
Much cheaper from powerflex,i have a thread on the same subject "tyre wear",gotta get mine done asap,just spoke to the guy who works on my car and he reckons it aint a very easy job.He also said that all calibra's have the same bushe's.
Fostersice17
by Molecule » Thu Jan 26, 2006 5:57 pm
what bushes are to be replaced, location please, anyone knowz?
tara
Molecule
by TommyC » Thu Jan 26, 2006 6:56 pm
The ones on the semi-trailing arms (wishbones) on the rear suspension. There's two main bushes per side.
Fat'z did a bit of home grown camber correction a while ago and posted up what he did. Would be worth doing a search to see what it brings up??
Just found it in the How-to section........
<a href="http://www.clubcalibra.net/forum/articles.php?action=viewarticle&artid=25" target="_blank">http://www.clubcalibra.net/forum/articles....rticle&artid=25</a>
TommyC
by cornishtaz » Mon Jan 30, 2006 7:22 pm
Good article but very easy to get it wrong
cornishtaz
by Fostersice17 » Tue Jan 31, 2006 3:05 pm
Ok,just ordered my powerflex bushes from Demon Tweeks as Powerflex dont sell direct,total for the back with p+p was £91.00,spoke to powerflex so i know im getting the correct ones.
Fostersice17
by Sg-1 » Tue Jan 31, 2006 3:26 pm
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->Ok,just ordered my powerflex bushes from Demon Tweeks as Powerflex dont sell direct,total for the back with p+p was £91.00,spoke to powerflex so i know im getting the correct ones.<!--QuoteEnd--></div><!--QuoteEEnd-->
Have you got a link?????
by Fostersice17 » Tue Jan 31, 2006 3:42 pm
I rang them direct sg-1,as i could not find the right one on the website,plus wanted to make sure i was getting the correct set,so rang both powerflex and demon tweeks,part number is PFR80-440MLK
Fostersice17
by Fostersice17 » Tue Jan 31, 2006 3:43 pm
P.S If this helps give me some feedback!!! Aint bloody got any yet!!! Sad little grey box....
Fostersice17
by Sg-1 » Tue Jan 31, 2006 3:48 pm
<!--QuoteBegin-Fostersice17+--><div class='quotetop'>(Fostersice17)</div><div class='quotemain'><!--QuoteEBegin-->I rang them direct sg-1,as i could not find the right one on the website,plus wanted to make sure i was getting the correct set,so rang both powerflex and demon tweeks,part number is PFR80-440MLK<!--QuoteEnd--></div><!--QuoteEEnd-->
Cheers fella I will give them a bell. Are you going to fit it yourself??
by Fostersice17 » Tue Jan 31, 2006 3:54 pm
I was gonna,but spoke to the guy who does some mechanical work on my car and he said it aint that easy job.He is gonna charge me £70 to do the lot,plus with the current weather i don't really fancy working outside.So i will let him do it,gotta get it done im going through 2 tyre's at the back every 5-6 months now.
Fostersice17
