ABS fault - HELP!!
ABS fault - HELP!!
I recently took my car 4 an mot, it failed because the ABS light is on. The ABS does not function, anybody know why? I have only recently bought the car, the owner had aftermarket alloys on it, but he took these off and put 14" corsa GSI wheels on. When i bout the car the ABS light was not on, any ideas why? is it possible that the smaller wheels couldve cut throu an ABS wheel sensor cable? The garage said it could cost up to £800
for them to fix if worst came to the worst. Any ideas anyone?!
Doodley
Hi and welcome to the site [img]/smile.gif[/img]
Have a look at this and see if it can help, if you need more help just shout.
<a href="http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm</a>
<!--QuoteBegin-Doodley+--><div class='quotetop'>(Doodley)</div><div class='quotemain'><!--QuoteEBegin-->its 1993 k plate, someone said it could be the relay,how do i go about the tests you mention?thanks for your help<!--QuoteEnd--></div><!--QuoteEEnd-->
All the info you need is on the link, just sit back and have a good read [img]/smile.gif[/img]
<!--QuoteBegin-Doodley+--><div class='quotetop'>(Doodley)</div><div class='quotemain'><!--QuoteEBegin-->yeah i did! got code 55 - "faulty ABS ECU - defective check connections and power" before I replace it how can I check the power going to it?<!--QuoteEnd--></div><!--QuoteEEnd-->
Using a multimeter across the +/- i think
