I will have abs.
I will have abs.
by splinter » Fri Feb 10, 2006 6:21 pm
Ok i have had no ABS for about 2 years now.
Well the computer was not reading any codes, so looked at all sensors and there ok, well its taken me 2 years to find out its the abs mod !!!!
I have bought 3 and all wont fit, well i bought another one, and its the right one, so today i pluged it in,. and turned the key and within 3 sec, the abs light on my dash, witch has been on for 2 years went off. [img]/smile.gif[/img]
So all i have to do is get the thing fitted witch looks hard.. lol.
And the other stuff turned up today too. all the gaskits i need, and head bolts..
Gone for the z20let head gaskit. [img]/smile.gif[/img]
Will let you know she is going in to be fixed..
The old skyline gtr felt exciting even when it was in a car wash !!!!! :)
by RobbieV » Sat Feb 11, 2006 6:02 am
Bout bleedin time [img]/laugh.gif[/img]
by splinter » Sat Feb 11, 2006 3:55 pm
hahaha thanks.[img]/smile.gif[/img]
by RobbieV » Sat Feb 11, 2006 3:58 pm
<!--QuoteBegin-splinter+--><div class='quotetop'>(splinter)</div><div class='quotemain'><!--QuoteEBegin-->hahaha thanks.[img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
Knew you would be happy [img]/smile.gif[/img]
by pas » Sat Feb 11, 2006 4:36 pm
Didnt want to start another topic - my abs worked fine but few days ago my gearbox flew apart and i put new one in (mine is 8v and new gearbox is f16cr) and now my abs light is staying on and abs doesent work (I tested it) - any idea why this happened?
Something happen when gearbox was changed - i checked that maybe it didnt unplluged but all sensors are pluged in...
pas
by RobbieV » Sat Feb 11, 2006 4:38 pm
Have you checked for codes ? if not look here -
<a href="http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm" target="_blank">http://www.topbuzz.co.uk/info/abs_codes/abs_codes.htm</a> [img]/smile.gif[/img]
by pas » Sat Feb 11, 2006 4:48 pm
thanks - i'll try that and see what happens...
pas
by RobbieV » Sat Feb 11, 2006 4:51 pm
<!--QuoteBegin-pas+--><div class='quotetop'>(pas)</div><div class='quotemain'><!--QuoteEBegin-->thanks - i'll try that and see what happens...<!--QuoteEnd--></div><!--QuoteEEnd-->
Okey dokey [img]/smile.gif[/img]
by pas » Sat Feb 11, 2006 5:10 pm
That was easy and fast - thanks again!
I get 12 - 41 -12 - 41 -12 - 41... and so on, I checked chart and it says - LH Front Speed Sensor - so should I unpllug ait and try to clean it or what?
pas
by RobbieV » Sat Feb 11, 2006 5:13 pm
Yes check to make sure the connections are clean and there are no breaks in the wiring [img]/smile.gif[/img]
by pas » Sat Feb 11, 2006 5:19 pm
Getting dark now so it will have to wait for tomorow morning...thx, ill post results
pas
