rims on cally T .... offset help!!
hi looking at getting a set of rims for my 4x4 cally turbo...
they are used.....
the question basically is... will they fit my car??
specs...
18" by 7.5" ..
tyres
215/35/18
offset
+52
i know they will fit but the worrying thing is the offset.. i know that the stock one is +49 and these rims are wider by an inch ... i know you can have around 40 offset but what about a 52 offset??
please help as they are really cheap and i can get these drilled to my stud pattern... cant find cheaper rims here.. so need to know if they are a go or not..
uess i could always fit spacers no???
they are used.....
specs...
18" by 7.5" ..
tyres
215/35/18
offset
+52
CAL.16V
been to a few wheel suppliers here in aus and that is the only pcd they have said they wpould drill for me ...
it is probably the most popular 5 stud pcd too... the redrilling would be in between each of the current holes and a little closer to centre of the wheel....
a few cally guys have it done here in aus as the 5x100 pcd is basically extinct bar 2-3 wheel types
so anywyas had a look underneath the car and the front tyre is really close to the struts so yous sure this would be ok??
worst comes to worse can i use something like this?
<a href="http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&rd=1&item=4612572458&ssPageName=STRK:MEWA:IT" target="_blank">http://cgi.ebay.com.au/ws/eBayISAPI.dll?Vi...me=STRK:MEWA:IT</a>
only worried about how i would get the wheel on with them as we got bolts not wheel nuts and also wondering if i would need longer custom wheel bolts say for a 5 or 8mm spacer?
CAL.16V
<!--QuoteBegin-CAL.16V+--><div class='quotetop'>(CAL.16V)</div><div class='quotemain'><!--QuoteEBegin-->once again i know the pcd is 5x110... gotta get them redrilled...<!--QuoteEnd--></div><!--QuoteEEnd-->
So whats this 5x100 you mentioned ?
