What pins do I connect to do the ABS paperclip test?
The topbuzz guide says pins "A" and "K" on the left hand side, which are directly above each other in the diagram.
However, after doing a bit of searching here, I noticed a couple of folk saying that the ECU paperclip test should be carried out using "Pin A and the fourth one along".
What one is correct?
Red_Calibra
