Scraping sound & Stiff Handbrake....?
I got home today and the handbrake seems a lot tighter than usual... doesnt travel as far as usualy, and it feels like there is something stopping it...
Just went out again, and I can hear a metallic scraping sound from the rear left in time with the wheel goin round...
The handbrake is still holding the car, but definitely feels a lot different, and isnt moving as far...
Anyone any idea whats going on there???
craigmcd82
<!--quoteo--><div class='quotetop'></div><div class='quotemain'><!--quotec-->sounds like one of your shoes has come detached<!--QuoteEnd--></div><!--QuoteEEnd-->
Sounds like you're right. The garage have said they can spend hours cleaning up each side, and putting them back together, but I figured it might be a better idea (and possibly cheaper) to just replace the discs...
Can anyone tell me what diameter the rear discs are for an 8valve (95)? Front would be good as well, - il do them myself... Part numbers would be even more useful!
craigmcd82
Brakes
Dual circuit, diagonally split system with direct action servo.
Front : 10.1in dia ventilated disc brakes with floating calipers. (8v / 16v)
Front : 11.2in dia ventilated disc brakes with floating calipers. (V6 / Turbo)
Rear : 10.2in dia disc brakes with fixed calipers (8v / 16v)
Rear : 10.6in dia disc brakes with fixed calipers (16v 4x4 / V6 / Turbo)
All models : Electronic anti-locking braking system (ABS). Asbestos-free friction material. Hand brake-on and low brake fluid warning lights. Plastic coated brake pipes. Hand brake mechanical, acting on rear wheels.
Cheers Fraz.... However, I've just found out that this wont solve my problem as the shoes dont come with the discs... Good info though.
Im having trouble explaining to garages whats wrong with it...dont quite know myself! Apart from new brake shoes, am I likely to need anything else to get this sorted?
craigmcd82
Take the hub off and have a look at where the pin and spring should be. mine did this and the scrapping sound was the pin stuck under the shoe and rubbing on the inside of the hub.
Re attach the pin and spring (may be tricky if the hole has rusted) and all should be ok
Rob
Rob
