Front control arm bush - part number?
I'm after a front control arm bush (the horizontal bush) for my C20XE 1991 2.0L 16v Calibra. I have had repeated oil leaks, and as I'm confident they are now nearing their end, I need to replace this bush on the drivers' side.
I have two part numbers. Could someone please validate which one (or if both) are compatible with my model.
I rang up Holden over here and they said the correct bush for my model (c20xe) is 90373263.
There is an eBay listing for the same bush under 90373778.
Can I use either bush, or ONLY the 90373263?
Any advice (preferably a direct answer to my questions) would be BRILLIANT!
Cheers, Paul [img]/wink.gif[/img]
100ney
davefly76
