springs question
springs question
hi,
lowering a 4x4 cally not easiest thing to do unless your rolling in it.
I have seen some ebeich springs that lower 25mm and fit my standard shocks should i get these or wait until i can afford some shocks aswell. will they b any better on standard shocks. also if i bought the springs and some other shocks from different company would they fit together, thanks. brett
btom
shouldnt matter if the springs/shocks are different makes, unless they are designed to be used with a particular type. i've lowered mine on standard shocks and tbh its not the best in terms of ride can be very harsh and also can bounce around a bit on uneven surfaces. im now looking at changing again for a full spring/shock set up so that should answer you question.
chief
