what brake dics
what brake dics
by ecosseM » Tue Apr 04, 2006 6:04 pm
whos got what on there cars out there? any comments, good and bad on current and past products appreciated...
ecosseM
by TonyDTM » Tue Apr 04, 2006 6:09 pm
<!--QuoteBegin-ecosseM+--><div class='quotetop'>(ecosseM)</div><div class='quotemain'><!--QuoteEBegin-->whos got what on there cars out there? any comments, good and bad on current and past products appreciated...<!--QuoteEnd--></div><!--QuoteEEnd-->
EBC / green stuff, red stuff, new yellow stuff... all have pretty good reviews. The EBC discs for the cally are drilled (stopped holes, not all the way thru) and grooved front and rear. Some ppl are advertising on Egay for silly money.
Personally i run mine on totally standard VX parts. N/S front pads started to squeal after 600 miles and rear O/S shoe squeaks every time the handbrake is applied.
I will be changing the whole lot by June or ealier if money allows.
TonyDTM
by ecosseM » Tue Apr 04, 2006 6:25 pm
had ebc, wont touch the discs again.. like the pads
ecosseM
by RobbieV » Tue Apr 04, 2006 6:40 pm
Got front/rear grooved discs from this chap -
<a href="http://stores.ebay.co.uk/sportbrakediscs_W0QQssPageNameZstrkQ3amefsQ3amesstQQtZkm" target="_blank">http://stores.ebay.co.uk/sportbrakediscs_W...sQ3amesstQQtZkm</a>
He can do them drilled and grooved or just drilled or like mine just grooved, good prices and ive not had any problems with them [img]/smile.gif[/img]
by calibra_v6_dtm » Tue Apr 04, 2006 6:44 pm
yeah i've been thinking of getting those
calibra_v6_dtm
by ecosseM » Tue Apr 04, 2006 6:52 pm
yeh was speaking to him earlier, all in for the combo, about £70.. for mine. tried to see if would do a club discout but wasnt up for it
ecosseM
by dj_smurph » Wed Apr 05, 2006 4:30 pm
black diamond combi with greenstuff pads
fantastic braking with no fade
dj_smurph
by thecrow » Thu Apr 06, 2006 11:20 pm
I've got some of the ebay ones - they're fine - starting to show tiny cracks from a couple of holes but they've had a reasonably hard life...
Not bad for the money IMO
thecrow
by Mark1 » Fri Apr 07, 2006 7:05 am
I've just fitted Red Dot 308mm 20 groove discs and they seem to work well.
by imcsherry » Fri Apr 07, 2006 8:39 am
I've just fitted Tarox 6 pots and 300mm 60 groove discs and predator pads up front and am getting some Skyline GT32R 4 pots modified to fit the back with black diamond drilled and groove discs, hopefully it will be spot on. I was running the Hi Spec 4 pots with 300mk drilled and grooved discs with greenstuff pads up front and they were great, I just wanted something REALLY good.
imcsherry
by Add_Gee » Fri Apr 07, 2006 8:46 am
<!--QuoteBegin-RobbieV+--><div class='quotetop'>(RobbieV)</div><div class='quotemain'><!--QuoteEBegin-->Got front/rear grooved discs from this chap -
He can do them drilled and grooved or just drilled or like mine just grooved, good prices and ive not had any problems with them [img]/smile.gif[/img]<!--QuoteEnd--></div><!--QuoteEEnd-->
One thing iv noticed with them.... some of the groved disks, the grove dosent go all the way to the edge of the disk. Isnt this needed to let the dust/heat escape? meaning as the pad is passing over the grove there will be a build up of dust / heat that gets trapped in the grove with nowhere to escape....?
or is that just rubbish [img]/rolleyes.gif[/img]
Add_Gee
