Camber
Camber
Ive changed the following on my car.
1) 18" wheels
2) Bilstein Premium suspension
3) Cav16 website camber kit
4) setup by power engineering
The camber suggested by cav16 should be between -1.25 and -1.5 i can only manage 1.5 on the drivers rear and -2 on the passenger rear. I dont know why this is. Ive had the components looked over for visable damage and there is none. Saying this the toe of the rear is spot on.
Any suggestions would be nice..
Question 2) I have a similar problem on the drivers front the camber is -1.5 where the passenger front is -.5 i have changed the following on the front
1) Wishbones
2) Drop Links
3) Track rod ends
4) Bilstein Premium suspension
5) 18" Wheels
6) Setup by power engineering
The tracking is spot on and the car does not wonder off or anything
Stu
1) 18" wheels
1) Wishbones
2) Drop Links
3) Track rod ends
5) 18" Wheels
Stu
ice
What offset are the alloys?
the lower the offset the higher the camber will be, vaux are ?ET49?
My camber was out even with maximum correction as i mentioned the other day, i put it down to that also. I cannot remember the figures, but i dont think it was as much as -2, it was -1.5 i think. I will try to dig it out later.
ice
worth asking them to have a look over, i wouldnt worry too much though, your figures seem to be within the spec that was listed on the printout i have. by the time you sit in the drivers seat you're going to create a bit more camber on the right anyway.. hehe.. probably work out ok, if not you just got to keep eating pies untill it does.
