What size/type bit needed for caliper bolts?
by Leigh » Mon May 29, 2006 2:32 am
Nice quick easy question for someone..
What size allen key or hex bit will fit the caliper bolts on a cally?
I was gonna change my front brake pads today, but 2 things stopped me:
i) they don't need it yet..
ii) the biggest allen key I've got is too small for the hex/star shaped caliper bolts.
So I'll need to buy the correct sized bit/key...
thanks
Leigh
by Fraz » Mon May 29, 2006 9:20 am
10 mm for the ones holding the caliper to the carrier
7mm the one to split the caliper (only need that to change the pads)
by Rusty_CallyT » Mon May 29, 2006 9:25 am
as said 10mm for the caliper to leg, best bet is a cut off 10mm allen key a 10mm socket and a huge breaker bar (they are usually pretty well in there)
Rusty_CallyT
by Tim2001 » Mon May 29, 2006 11:20 am
Get a set from halfords that go on a 1/2 drive ratchet (sp) one of the better investments I made in my tool set along with the in and out torx drive sets.
Tim2001
by TommyC » Mon May 29, 2006 12:00 pm
<!--QuoteBegin-Tim2001+--><div class='quotetop'>(Tim2001)</div><div class='quotemain'><!--QuoteEBegin-->Get a set from halfords that go on a 1/2 drive ratchet (sp) one of the better investments I made in my tool set along with the in and out torx drive sets.<!--QuoteEnd--></div><!--QuoteEEnd-->
I'll second that. I bought both individually from halfrauds. They're expensive for what they are, but will save a lot of hassle like cutting up allen keys etc. Think they're £3-£5 each.
TommyC
by Leigh » Tue May 30, 2006 10:47 am
Cheers guys, at the moment it's just the two to split the caliper when I (eventually..) do the pads. £5 ain't too bad I guess. I bought a 1/2" drive 17mm socket to go with my breaker bar last year,and at the time you think "that's expensive for a single socket", but the first time you use it and find it's SO much easier (especially when I'd broken 2 normal extension bars trying to undo a wheel nut!), then it kinda makes it worthwhile..
Just wish I'd bought the breaker and nut a few years previous.
Leigh
