Camber...
Camber...
by Rusty_CallyT » Mon May 29, 2006 8:58 pm
I noticed the inside edge/shoulder of my rear tyres on my standard calibra turbo were looking pretty worn. Its not lowered at all, any ideas what could be causing it?
Rusty_CallyT
by dj_smurph » Wed May 31, 2006 5:31 pm
the toe could be out on the rear get the tracking checked
dj_smurph
by Chavtastic » Wed May 31, 2006 5:36 pm
Previous owner not rotating the tyres as recommended
by chunkylover » Wed May 31, 2006 6:40 pm
Would advise getting a 4 wheel alinement check mate. The standard set up on the rear is not adjustable but you can get the camber correction kits which can be adjusted. I've just pick a set up from OZ beleive it or not and only cost me £90 inc P&P. Check the aussie ebay under Holden calibra. The other thing maybe that the last owner has swap the front to the rear as people normaly only check the front tyres when buying so the problem maybe at the front.
Are you breaking the old calibra think i may need an ecu
chunkylover
by Naz » Wed May 31, 2006 7:44 pm
Yes Adam
I was gonna say the rears aren't adjustable. So if its out, then the cause of it could be a bend something: suspension arm, worn noints and ...
Or it could easily have been the last owner reotating it from front to rear and not noticing the wear.
Get a tracking done, if the rear is out, you need to find out why. Don't just buy a correction kit to sort it out. if something is bent, then needs replacing.
If you then lower it, you WILL need a camber correction bush/kit. But don't expect to get much for the bush. All you get is a bush with the centre not in the centre [img]/wink.gif[/img] and its bloody expensive!
Naz
by Rusty_CallyT » Wed May 31, 2006 8:43 pm
had wheel alignment done before i noticed the problem.
I started this thread as i know the rears arnt adjustable. I will keep an eye on my 18's and see if i get an issue.
Will post my alignment printout in a min
Rusty_CallyT
by Rusty_CallyT » Wed May 31, 2006 8:48 pm
Any good? i have my doubts.
Rusty_CallyT
by Rusty_CallyT » Wed May 31, 2006 8:50 pm
ET38, also 2cm wider than the stock so sticking out an extra 11mm but 20mm wider so will be close to stock i think
Rusty_CallyT
by Rusty_CallyT » Wed May 31, 2006 8:59 pm
well thats ok then as the inner edge is the bit that causes problems when lowering etc with varying rolling radius etc.
Rusty_CallyT
