Bleed nipple snapped
by slugger_2003 » Mon Jun 05, 2006 10:54 pm
Hi all. I got hold of a brake master cylinder for £17 from a scrappy cuz my old one was knackered. After some fidling (I'm a bit of an amateur) I got the "new" one bolted on. Next came the process of bleeding the brakes. While attempting this the bleed nipple snapped and I was told to take it to a garage to get them to replace the nipple? They could either do that or I'd have to get new calipers? I was told that because one of the nipples snapped and all the others looked just as rusty that they would all probably snap. If I were to change the calipers then the brake pipes might snap which would lead to brake pipes needing to be replaced which I'm told is a lot of mechanics time. What's involved in changing the brake pipes if they do snap? Where should I buy my calipers and pipes (potentially) from? Any brands reccomended?
Anyone got any suggestions for what I should do?
In short, I have snapped one of the bleed nipples, what is the best course of action?
Thanks,
Matt
slugger_2003
by wilkybar-kid » Mon Jun 05, 2006 10:58 pm
When you say master Cylinder, do you mean the caliper behind the wheel?
If so you may well need a new caliper, I have not got a broken nippel out of one to date...
If you join up with Club Calibra as a full member you should get a good discount on that sort of stuff from Vauxhall. Just thought I had better throw that in there...
wilkybar-kid
by Rusty_CallyT » Mon Jun 05, 2006 11:10 pm
broken bleed nipples are a pain and can result in a new caliper (not cheap).
dont worry about brake pipes snapping thats bollox lol they are flexible.
best thing for bleed nipples is a tight ring spanner and a sudden shock (tap with a hammer) im told to release them.
Best bet is try to find a good replacement caliper from a scrappy.
Rusty_CallyT
by slugger_2003 » Mon Jun 05, 2006 11:15 pm
No, I'm talking about the brake master cylinder, It's located at the rear of the engine bay to the left next to the tank for engine coolent and sits under the break fluid resevoir.
So if I try to bleed the rest of the brakes and any of those nipples snap then I should look to a scrappys for a set of calipers for each nipple I snap?
slugger_2003
by slugger_2003 » Mon Jun 05, 2006 11:25 pm
This is the first link I've come across for a diagram of a brake master cylinder for any of you who are wondering. Bare in mind THIS LINK SHOWS THE BRAKE MASTER CYLINDER AND RESEVOIR FOR A VECTRA[U] and is NOT for the calibra. But it will give you an idea of what I replaced.
Matt
slugger_2003
by slugger_2003 » Mon Jun 05, 2006 11:26 pm
Forgot to post the link [img]/smile.gif[/img]
<a href="http://cgi.ebay.co.uk/VAUXHALL-VECTRA-BRAKE-MASTER-CYLINDER-parts-spares_W0QQitemZ4647174284QQcategoryZ10404QQrdZ1QQcmdZViewItem" target="_blank">http://cgi.ebay.co.uk/VAUXHALL-VECTRA-BRAK...1QQcmdZViewItem</a>
slugger_2003
by slugger_2003 » Mon Jun 05, 2006 11:28 pm
Sorry for the mass posting. Just wondered, will vectra or any other calipers fit the calibra?
slugger_2003
by Rusty_CallyT » Mon Jun 05, 2006 11:32 pm
cav or calibra. maybe astra, just need to find some big enough
Rusty_CallyT
by slugger_2003 » Mon Jun 05, 2006 11:38 pm
So calipers off any cav or calibra would do? What sizes should I look for? Like the minimum and maximum?
Would the goodridge brake line kit for the turbo fit onto my 2.0 16v Redtop?
slugger_2003
by Rusty_CallyT » Mon Jun 05, 2006 11:56 pm
should think the 1.8 / 2.0 cavs would have the right ones, its hard to say for sure
any 8v/16v calibra will do tho
Rusty_CallyT
