Wheel rubbing
Wheel rubbing
by hormonedmonkey » Tue Jun 27, 2006 1:37 pm
Amateur question but......
and please excuse my ignorance..... i'm learning slowly.....
my wheel is making a rubbing noise as it goes round. Its the caliper part rubbing on the disc......
what can I do?
hormonedmonkey
by imcsherry » Tue Jun 27, 2006 3:26 pm
Change you brake pads by the sound of it!
imcsherry
by Phil69 » Tue Jun 27, 2006 10:42 pm
Could be the pads. Depends on the noise....it could be the shield catching the disc. Like i said, it depends on the noise. Difficult to say without hearing it.
by Welsh_Andy » Wed Jun 28, 2006 8:54 am
could be the shield,as i had that prob after i changed discs.
what type of noise is it,rubbing as in metallic,whirling noise etc?
Welsh_Andy
by hormonedmonkey » Wed Jun 28, 2006 10:12 am
yep metallic whiring
hormonedmonkey
by johnny_adidas » Wed Jun 28, 2006 10:47 am
check the shield first as its the quickest thing to check. then check youy pads.
metallic whirring sounds like your shield though. it would be kind of a high pitch whirr.
completely worn pads would be a grinding dull kind of noise. new pads and ones which are just coming to the end of the life (ie informing you its nearly time to change them) can make a high pitched squeel.
also is it back or front?
johnny_adidas
by hormonedmonkey » Thu Jun 29, 2006 9:25 am
front.
hormonedmonkey
