quick driveshaft Q
quick driveshaft Q
by stiofansisland » Sun Jul 30, 2006 7:29 pm
is the 8v and 16v drive shafts the same? o/s
thanx in advance
stiofansisland
by Rusty_CallyT » Sun Jul 30, 2006 7:46 pm
should be iirc
Rusty_CallyT
by Phil69 » Thu Aug 03, 2006 12:42 pm
Not neccessarily.
The 8v more commonly has one long shaft from the gearbox to the hub (not all the time though) where as the 16V more commonly has a split shaft that mounts to the back of the engine on a centre bearing with a drive shaft with the 2 cv joints connected from that to the hub. Again, not all the time but as I said, these are onyl the more common types that I've found.
The split shaft is more bulky....and stronger than the long thin one.
If it was the left hand side then yes I believe they are the same.
Users browsing this forum: Google [Bot] and 13 guests
